Code 37, 32, 17 1995 Ram 4x4
Old May 22, 2011 | 10:22 PM
kentuckydodge's Avatar
kentuckydodge
Default Code 37, 32, 17 1995 Ram 4x4
I have a 95 1500 4x4 318. My check engine light is on. I am getting codes 37,32,17
It's shifts a little hard when going in to high gear. Seems like it don't have the power it should. I changed the trans filter and fluid.
Also have 2 sets of wires, at the back of the trans that are not connected. Don't know what they are.
Also, steering is a little loose, ball joints seem ok. Any thoughts?
Any help would be great.
Old May 22, 2011 | 11:48 PM
dodgeram07's Avatar
dodgeram07
start https://dodgeforum.com/forum/1st-gen...d-1-codes.html
37 Torque converter clutch solenoid CKT or park/neutral switch failure
32 EGR system failure( dont brother fixing mine comes and goes) still runs the same
17 Closed loop temp not reached or engine cold too long,, what temp is the truck running at?,, maybe replace sum coolet senor units?
