new tranny cooler pics
Old May 28, 2011 | 04:33 PM
dodgeman2289's Avatar
dodgeman2289
I dont use my a/c anymore. Had my top dash replaced awhile back was cracked. And ever since then it dont blow out the vents just the defrosters
Old May 28, 2011 | 05:48 PM
UnregisteredUser's Avatar
UnregisteredUser
Originally Posted by aim4squirrels
Might want to replace the rubber flaps on the sides of the radiator now that you have the extra bulk up front.
Just dogpiling on to say "ME TOO!". I recommend getting those dams back on there.
Oh, and if the A/C struggles now, move the cooler to behind the A/C condenser. That's where the factory put the coolers on trucks with the towing package.
Old May 28, 2011 | 06:47 PM
dodgeman2289
Might want to replace the rubber flaps on the sides of the radiator now that you have the extra bulk up front. It'll channel more air thru the radiator, and keep the driving rain away from your PCM, too.
ive removed both sides along time ago.. the flaps..
Old May 28, 2011 | 09:20 PM
mctdi's Avatar
mctdi
You might want to rotate the cooler so at least the outlet is on top. This so air will bleed out instead of becoming trapped in it.
Old May 28, 2011 | 09:25 PM
dodgeman2289
Been working fine the way it is.. no sense changing something that aint broke or affecting in a negative manor
