Rear Spring Replacement ???
Old May 28, 2011 | 10:15 PM
mctdi's Avatar
mctdi
Default Rear Spring Replacement ???
When replacing rear springs, does the fuel tank have to be dropped to get at the left front bolt? Can the bolt be removed and replaced, too?
Thanks
Old May 28, 2011 | 11:40 PM
97tn4x4's Avatar
97tn4x4
Yep. I was told you could pry the tank enough to wiggle the bolt out but I'd much rather just drop the tank. I took the bed off as well. So much more room.
Old May 29, 2011 | 10:21 AM
grox's Avatar
grox
I cut as much off of the bolt as I could and managed to get it off/on.
