abs and brake...
Old Jul 8, 2005 | 10:37 AM
Jman1's Avatar
Jman1
Default abs and brake...
well.... i replaced the rear wheel sensor... lest the battery unplugged for an hour.... and the lights are still coming on.... anyone with any other ideas????
Old Jul 8, 2005 | 04:51 PM
steve05ram360's Avatar
steve05ram360
Default RE: abs and brake...
out of the manual for a 2001...
"the CAB (controller for ABS) moitors the following inputs to determin when a wheel lock tendency may exhist:
Rear Wheel speed sensor
brake lamp switch
brake warning lamp switch
reset switch
4wd switch (if equipped)."
the outputs are to the ABS valve, and the 2 lights that you have on. the manual doesnt say how to test each part in the section I found this in. Check your codes stored in the computer. there may be a new code in there which might point you in the right direction.
HTH...
