spark plug heat shields
Old Jun 20, 2011 | 01:15 PM
bigaaron's Avatar
bigaaron
Question spark plug heat shields
Geting ready to do a tune up. How do I get the spark plug heat shields off or do I need to buy a special socket? Mine are pretty corroded.
Old Jun 20, 2011 | 01:19 PM
aim4squirrels's Avatar
aim4squirrels
Pull them out with vise grips and don't look back, might need some rust penetrant to get them to budge.
Old Jun 20, 2011 | 01:21 PM
Annihilator_X9's Avatar
Annihilator_X9
Do we even need those things? I was thinking of removing them but afraid the heat from the exhaust manifold might melt my wires.
Old Jun 20, 2011 | 01:54 PM
talthyren's Avatar
talthyren
Are you talking about the metal shields around the spark plug holes? or the plastic "Boots" that connect to the plugs?
I have never had an issue with the metal shields...just use a small ratchet extension and standard plug socket...no problem.
Old Jun 20, 2011 | 02:19 PM
Annihilator_X9
I'm talking about the metal shields. And it's not that you can't remove the plugs, but people say water/dirt get caught in them and cause the plugs to rust and create a general pain in the rear to get them out.
Old Jun 20, 2011 | 02:21 PM
talthyren's Avatar
talthyren
I always take compressed air and blow them out good before I remove the plugs...good point though, you defiantly don't want crap falling into the plug hole.
Old Jun 20, 2011 | 03:25 PM
Hahns5.2's Avatar
Hahns5.2
This.
Old Jun 20, 2011 | 06:39 PM
dhvaughan's Avatar
dhvaughan
throw them away. far far away.
Old Jun 21, 2011 | 11:14 PM
bigaaron's Avatar
bigaaron
i cant get the socket to grab the plug with the shield on. (at least the one i tried) Can I pull them off with the plugs in?
Any known effects from leaving them off?
Old Jun 21, 2011 | 11:36 PM
dhvaughan's Avatar
dhvaughan
yes, you can remove the tubes with the plugs installed - just be careful not to break a plug.
use pliers to pull on them, or a hammer to GENTLY tap them side to side.
