Need major help with repairs
Old Jul 11, 2005 | 04:46 PM
Bahnstorminge30's Avatar
Bahnstorminge30
Default Need major help with repairs
Hey whats up everyone. This is my first of many posts now that I found this forum. Ok so here is the deal I have a 1994 1500 2wd with the 318. The problems I am having are abundant. First and prolly the biggest is stalling. When I start the truck it idles really rocky and I usually turn the truck off and restart it and its a bit better. But it rumbles like its a deisel. Not really sure what the deal is with that but when I get to a stop light I have to keep on the gas while I am also on the brake so I don't stall. It really gets rocky and I am using alot more gas now. I don't want to go to a shop cause the truck isn't really worth all that much since it is kinda beat up but its all I have right now. I also found that every now and again my oil pressure gauge kinda dips off and the once I hit the gas it comes back to normal. But the little oil light comes on when the oil pressure dips. Any help would be greatly appreciated.
Thanks
Peace
Pete
PS one other problem. I also noticed that when I make a left turn on a slight incline there is a clunking noise coming from the rear end. It sounds like the tailgate is loose but its not and I am not sure what this might be. Thanks again
Old Jul 11, 2005 | 04:51 PM
greenmachine's Avatar
greenmachine
Default RE: Need major help with repairs
Try cleaning or replacing the IAS (idle air sensor) 70$ part at the dealer. In fact just clean all the sensors in the throttle body. Should be an easy fix
Old Jul 11, 2005 | 08:34 PM
1500sport's Avatar
1500sport
The oil pressure problem could be a dirty pickup tube, low oil, or bad rings depending on how bad it is. My dad bought a 94 5.2L that had the crap ran out of it. Oil pressure was bad, smoke real bad and used about 2 quarts of oil in a 100 miles, and the motor had a loud knock similar to the new quietier diesels. Unfortunately the motor had to be rebuilt. Don't want to scare you but it all depends on your problems.
Old Jul 11, 2005 | 10:04 PM
Bahnstorminge30
hey everybody thanx for your advice, i had my mechanic friend look over the engine and he said the EGR Transducer has melted and is causing a vacuum leake when it opens, i do hear a hissing sound underneath the hood and i just wanted to see if you guys knew anything about these transducers
