How to end the ANNOYINGNESS!?
Old Jul 3, 2011 | 06:25 AM
tweav88's Avatar
tweav88
Default How to end the ANNOYINGNESS!?
So as all of u guys should know, when you open your door and the key is in the ignition, there is a very loud and annoying alarm thing that goes off(idk how else to describe it).
I've heard that in fords, there is a way to get that alarm to stop by doing a combination of random things(a certain code) that will eliminate the noise from happening again.
Is there any such thing that you can do on our trucks?
Thanks, Tweav
Old Jul 3, 2011 | 08:32 AM
charlie1935's Avatar
charlie1935
Easy cure. Don't leave the key in the ignition!
Old Jul 3, 2011 | 08:52 AM
Novarider's Avatar
Novarider
Roll the window down and shut the door
Old Jul 3, 2011 | 09:31 AM
Sheriff420's Avatar
Sheriff420
Pull the key out a little or wait 15 minutes. Our trucks have something called party mode where after 15 minutes with the door open the dome light cuts off and I think the chime stops.
Old Jul 3, 2011 | 09:55 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by Sheriff420
Pull the key out a little.
+1... that's what I do. It becomes automatic in a few days.
Old Jul 3, 2011 | 11:52 AM
tweav88's Avatar
tweav88
Lol i already do that constantly, i just didnt know if you could just up and end it for good
Old Jul 3, 2011 | 11:59 AM
99dodge318's Avatar
99dodge318
i just turn the key all the way forward
Old Jul 3, 2011 | 12:07 PM
EndIsNear's Avatar
EndIsNear
I think under the cover for the steering column, connected to the key switch/cylinder, is two little wires, that I unplugged and it killed the sound, yet the alarm if your lights are left on still works. I have no idea if it applies to all years, but it worked in my '01...
Old Jul 3, 2011 | 12:27 PM
RamSport97's Avatar
RamSport97
I just pulled the buzzer module out. If you remove the interior fuse cover, you can see it. It is like 1" wide and 2 to 3" long.
Old Jul 3, 2011 | 01:59 PM
redheadhunter21's Avatar
redheadhunter21
^^^^^just pull the buzzer
