hard cold start and loss of power after hot?
Old Jul 10, 2011 | 07:11 AM
acf142's Avatar
acf142
Question hard cold start and loss of power after hot?
97 4x4 but a 96 ecm and 360
Okay first problem, after my truck sits and gets cold its like I'm loosing fuel pressue 2 the fuel rail it cranks and cranks till it starts but when it starts if runs rough for a min then back to normal... second problem, on a short drive its fine but if I go a long distens or pull a trailer and get the motor hot "within range of operating temp" it acts like I have a clogged cat loss of power and starts pooping if I slow down to a stop I can only pull out slow after a little longer it just wont pull out at all it starts to miss and pop then it seems like it starts loosing cyclinders one by one till it idels on what seems 2 be one or two cyclinders? any thoughts ??? Please help this one is really throwing me
Old Jul 10, 2011 | 07:36 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Have you checked the fuel pressure with a gauge? Have you had the cat checked? Your plenum might be blown and it's screwing up the o2 sensor. Read this for more info https://dodgeforum.com/forum/2nd-gen...um-thread.html
Old Jul 10, 2011 | 02:23 PM
acf142's Avatar
acf142
have not checked fuel pressur yet "Really not to worried about the hard start" and yes I have checked the cat "pulled exhaust off both manifolds after it started acting up while motor was still hot" didnt help... I read the plenum thred and some of the symptums line up but not all ... I can drive the truck 15 20 miles and it'll be fine then it starts acting up untill I let it cool down then it'll run like normal ... thinking about taking it somwhere to have them diagnose it and I'll just fix the problem myself
Old Jul 10, 2011 | 02:59 PM
zman17's Avatar
zman17
Replace the crank sensor then.It's a PITA,so don't get a cheap POS from autozone. Ge one from the dealer, or at the very least get a Standard Motor Products replacement.
Old Jul 11, 2011 | 05:37 PM
acf142's Avatar
acf142
Okay thanks 4 all the advice ... finally broke down and put a fuel pressure gauge on her
..... started at 30 psi and slowly dropped 2 about 5 or 7... time 4 a fuel pump lol
Old Jul 11, 2011 | 05:58 PM
zman17's Avatar
zman17
Yep, pressure should hold for at least a few hours after shutdown. And while running , should be close to 45.
Old Jul 11, 2011 | 09:25 PM
acf142's Avatar
acf142
Just finished new pump install
... pita by yourself I might add .. but got 46 psi running and let gaudge sit while I bolted bed back down and everything still had 28 psi ... about2 hours and 4 beers later lol
Old Jul 11, 2011 | 09:27 PM
zman17's Avatar
zman17
Good job.
Old Jul 12, 2011 | 07:54 AM
acf142's Avatar
acf142
Unhappy
befor .. engine running
Attached Thumbnails hard cold start and loss of power after hot?-low-psi.jpg
Old Jul 12, 2011 | 01:03 PM
zman17's Avatar
zman17
start it up and let pressure build, shut it off and quickly clamp the rubber supply line and see if pressure holds.
