Front End question
Old Jul 11, 2011 | 02:13 PM
S S0DEN's Avatar
S S0DEN
Default Front End question
4x4 1999 Ram
When you watch the front axle (vehicle started) and you turn the wheels left and right, the front axle moves just a little to the left and right. Is this normal, should their be a little play when steering or is the axle to be 100% rigid and not move at all?
When the wheel is turned, I can see the dana44 move just a little to the left and right.
I have a bad ball joint that is making some noise when turning, I was looking for the noise and witnessed this.
Old Jul 11, 2011 | 02:14 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Not normal, you need a new trac bar.
Old Jul 11, 2011 | 02:17 PM
S S0DEN's Avatar
S S0DEN
That sucks, that's the 2nd track bar in 3 years... I can see the ball joint on the track bar move in and out where it bolts to the frame, good call. Hope that's all it is - hard to believe the entire front axles stability rides on one ball joint (track bar) lol.
1&2genrams's Avatar
1&2genrams
Check your track bar, they are supposed to keep your front axle where it belongs but they wear out on all 2nd gens
Old Jul 11, 2011 | 02:27 PM
zman17's Avatar
zman17
What brand have you been buying? Get a MOOG if that's not what you have.
Old Jul 11, 2011 | 08:17 PM
dhvaughan's Avatar
dhvaughan
moog is just over $100 at rockauto.com
Old Jul 11, 2011 | 09:52 PM
S S0DEN's Avatar
S S0DEN
I think it was a TRW, the Moog was just a little more if I remember correctly.
