desperately need help
Old Jul 25, 2011 | 03:35 PM
Mill Man's Avatar
Mill Man
Originally Posted by redheadhunter21
Make sure you have the terminals on real good and there tight, if the battery will take a charge it should put out enough to start the truck. Might want to spray with some cleaner too if it wasnt already done. After the pcm resets if its not gettin good voltage it can stall out even though the alt is good.
With the door open you can watch the dome light to get an idea of good/bad connection
Just like redheadhunter21 said. Make sure the connection is good an tight. Any type of loose connection at the battery will cause this. I seem to have forgotten one of the Most important parts of diagnosing starting issues. I just replaced my plenum gasket on mine and had the same issue. I would just click. I looked at my neg battery terminal and it was all but gone.
Old Jul 25, 2011 | 08:38 PM
Coltybear's Avatar
Coltybear
Problem Solved!! I went and got a new interstate battery and put it in today. chipped the buildup off the terminals and hooked it all back up tight. got in, sat there for a second preparing to cry if it didnt start. tryed it and fired up after the first roll!!! thanks for the help guys
