cel on rough idle p308 code
Old Aug 9, 2011 | 05:17 PM
sullivanj04's Avatar
sullivanj04
Default cel on rough idle p308 code
So no problems since I have had the truck pulled a 30greasy ft. 7k pond camper a few times with no major issues and now I was running around town still running fine I floored it to get out into tragic wot only through first gear ans let off nothing right away pulled into my driveway about 2 minutes later and its iddleing rough and the rpm is between 1200 and 900 back and forth. Turned it off and when I went to start it this morning it was still iddeling like crap and the cell is on pulled the code and I got p308 cylinder 8 misfire what would cause this and how do I fix it thanks
Old Aug 9, 2011 | 05:19 PM
sullivanj04
Oh and not a 30greasy ft trailer but a 30 ft trailer lol not sure why my phone did that
Old Aug 9, 2011 | 05:52 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Plenum is blown and your cat is clogged. Read this, https://dodgeforum.com/forum/2nd-gen...um-thread.html
Old Aug 9, 2011 | 05:55 PM
sullivanj04
The seller said the cat has ben gutted could it be the plenum and a bad 02 sensor
Old Aug 9, 2011 | 06:09 PM
zman17's Avatar
zman17
Yea, or a cracked head if the cat wasn't gutted soon enough.
Old Aug 9, 2011 | 06:18 PM
sullivanj04
How can u tell if the head is cracked id rather find that out first before I replace the plenum gasket
Old Aug 9, 2011 | 06:40 PM
zman17's Avatar
zman17
Compression and /or leak down test.
Old Aug 9, 2011 | 08:33 PM
sullivanj04
I duble check my intake took the air box off and seems to be alot of oil in the intake so im hoping fixing the plenum will solve the issue
Old Aug 10, 2011 | 08:24 AM
zman17's Avatar
zman17
The cat will most likely be clogged too, and replace the front o2 sensor also.
