4x4 and 4x2 rear end, are they equivalent
Old Aug 11, 2011 | 01:07 PM
Buck Slayer's Avatar
Buck Slayer
Originally Posted by zman17
Like dhvaughan said, the springs are different width and the yoke will be different from a 2500, so the shaft won't fit.
youre right it wont, but either i can pull that drive shaft (probably not what ill do) or take mine to a shop an get a custom yoke put on. i have been pm'ing meanwhitemopar who did this and he told me it would cost about 60 bucks.
Old Aug 11, 2011 | 01:11 PM
zman17's Avatar
zman17
Retired Moderator - RIP
It'll be more than 60 most likely. But more important, the springs won't work either without modification/welding.
Old Aug 11, 2011 | 01:23 PM
Buck Slayer
ill have to reweld the perches and what else?
Old Aug 11, 2011 | 01:37 PM
zman17's Avatar
zman17
If you use the 1500 springs, nothing else.
Old Aug 11, 2011 | 02:04 PM
Buck Slayer
what will have to be done to use the 2500 springs?
Old Aug 11, 2011 | 02:08 PM
zman17's Avatar
zman17
The front and rear leaf spring mounts on the frame are different.
Old Aug 11, 2011 | 02:20 PM
Buck Slayer
but all that needs to be put on are the hangers or something right?? i thought ive read about this being possible on here somewhere.
Old Aug 11, 2011 | 02:33 PM
zman17's Avatar
zman17
Sorry, but a 2500 axle doesn't just simply bolt on to a 1500. The perches and at least the front leaf spring mounts are welded to the frame. So there is more fab work than you think. IMHO, for the sake of wanting to install 8 lug wheels on a 2wd 1500, is just plain not worth it. Get the adapters, or sell those wheels and buy a nice set of 5 lugs.
Old Aug 11, 2011 | 04:50 PM
SpencerS's Avatar
SpencerS
to the OP, are you SASing this truck or just swaping out the rear axles?
Old Aug 11, 2011 | 04:56 PM
zman17's Avatar
zman17
He just wants to put 8 lug wheels on a 2wd.
