As far as I can tell yea. Just make sure you have fuses inline and a multi meter handy. LOL I know one thing for sure. Not only is the OEM gauge wire not sufficient (fine if your doing your own) but the switch itself may not be up to the task.
BINGO!! I got it! the numbers for the pins on the diagram where not the same as on the switch it self(same numbers different order). So after looking closer I wired it correctly and it works perfect! Thanks for the help guys!! If anyone is interested in how i did it let me know.
How plug-N-play is adding fog lights?
Is all the wiring there from the factory, just plug in fog lights, a switch and relay in the PDC and your done or is that way to easy ? LOL
