my front end/brakes grind when I brake abruplty?
Old Aug 11, 2011 | 11:27 AM
vikingdiesel's Avatar
vikingdiesel
Default my front end/brakes grind when I brake abruplty?
Its hard to explain but if i brake hard abrubtly, ill get this grinding/ rubbing kinda scary sound from the brakes as if they're locking up?? When i brake normal, everything is fine, no issues, its literally ONLY when i brake hard all of a sudden
Old Aug 11, 2011 | 11:37 AM
zman17's Avatar
zman17
Retired Moderator - RIP
You have 4 wheel anti lock brakes ?
Old Aug 11, 2011 | 11:57 AM
vikingdiesel
I dont know bc i do have the ABS light on dash when i start the car but i dont have the abs connector in the front hub, i have the rear abs i think
Old Aug 11, 2011 | 12:01 PM
zman17's Avatar
zman17
You'll have wires running to the front hub bearing assemblies if you have 4 wheel anti lock.
Old Aug 11, 2011 | 12:18 PM
redheadhunter21's Avatar
redheadhunter21
Have you checked your pads, and are the rotors smooth or do they have lines in them
Old Aug 11, 2011 | 12:21 PM
zman17's Avatar
zman17
The slide pins may also be seized.
Old Aug 11, 2011 | 12:45 PM
Silverdodge2001's Avatar
Silverdodge2001
Sounds like anti-lock brakes to me.
