H2 wheels
Old Aug 13, 2011 | 10:00 PM
angelo's Avatar
angelo
Default H2 wheels
Would Hummer H2 wheels fit a 3/4 ton truck. I know the bolt pattern is the same but would the hub size be the same.
Old Aug 14, 2011 | 04:36 AM
MoparMan1991's Avatar
MoparMan1991
Ill be honest, It looks like ****. I've seen people do it before and it just looks like trash.
Old Aug 14, 2011 | 10:27 AM
Ram_King's Avatar
Ram_King
its kind of a hit or miss, some truck you have to make the whole bigger some don;'t its all luck of the draw
Old Aug 14, 2011 | 02:03 PM
angelo's Avatar
angelo
well did some research and found out that the hummer wheels have a smaller center hole than the dodge ram. and you would have to machine the wheels if it was to fitr which is too much trouble
Old Aug 17, 2011 | 10:33 PM
Hans_GZP's Avatar
Hans_GZP
I just had to bore out the center a little bit. There is a lip in the center hub that you have to grind up to. I ended up using an aluminum porting bit and it didn't take very long with an air die grinder.
