Heater Changing Positions Automatically
Old Jul 18, 2005 | 10:53 PM
antz_ram's Avatar
antz_ram
Default Heater Changing Positions Automatically
Like the title says. My heater/Ac will change positions from vents to defrost on it's own. I have no idea what could be doing this? If someone can help me i would appreciate it! thanks.
-Anthony-
Old Jul 19, 2005 | 12:11 AM
2kramquad's Avatar
2kramquad
Default RE: Heater Changing Positions Automatically
If it's doing it when you get on and off of the throttle then you've got a vacuum leak.
Old Jul 19, 2005 | 10:28 PM
antz_ram's Avatar
antz_ram
how do I check to see if it is a vacuum leak?
Old Jul 22, 2005 | 08:32 PM
antz_ram's Avatar
antz_ram
anyone?
Old Jul 23, 2005 | 04:56 AM
HuntinHanson's Avatar
HuntinHanson
go to autozone and rent a hand help vacuum pump.
Old Jul 24, 2005 | 03:11 AM
mxmancr250's Avatar
mxmancr250
When you get in the truck, do your eyes turn yellow, your head spins around and then you puke all over the place? If so you may need a preist to get this fixed. You can try Autozone too.
Old Jul 24, 2005 | 02:13 PM
steve05ram360's Avatar
steve05ram360
there is a check valve in-line on the vacuum line that goes thru the firewall that is bad.
check in here for the TSB... http://www.dodgeram.info/tsb/
