Gurgling sound when starting
I am guessing moisture under the passenger side carpet is a sign of the heater core crapping out on me?
The only other thing I can think of is that my windshield leaks and it is left over from rain, as it doesn't have a antifreeze/glycol smell to it.
Get the truck warmed up and then turn on the defroster. If some kind of haze forms with a slight sweet stench, it's the heater core.
As far as burping the system goes, this can be found in the FAQ section that is worth looking through. Only thing that should be added to it, is getting the right front up as high as you can. https://dodgeforum.com/forum/2nd-gen...nt-system.html
And, I could be wrong, but I think the timing chain is on the front of the motor. A Haynes manual or the free service manual download(which is also located in the FAQ section) might help.
https://dodgeforum.com/forum/2nd-gen...e-manuals.html
