A few questions for ya
Old Aug 24, 2011 | 09:01 AM
Jason Van Order's Avatar
Jason Van Order
Default A few questions for ya
Ive got a 97 1/2 ton with the 5.9. The water pump went out so gotta replace that. My questions are the pump that is on there has a bolt on pulley and the parts store tells me the only one avalible has a press on pulley will there be any issues going from one to the other? Also what threads are on the fan clutch i know most are reverse thread but i think i heard that these have normal threads is it true? Thanks for your help
Old Aug 24, 2011 | 09:19 AM
zman17's Avatar
zman17
Retired Moderator - RIP
IIRC, they are regular right hand thread. You might want to consider doing the timing chain also. At the very least the TC cover gasket, as it usually gets damaged and leaks after a water pump replacement. As far as the pulley goes, I suppose you could take the old pump off and match it up to the new one..
BTW, Rock Auto list both styles of pumps. I'd say go to a different parts store.
