Loud buzzing...
Old Aug 24, 2011 | 08:42 PM
zje400ex's Avatar
zje400ex
Default Loud buzzing...
Few years ago when i was driving home from work the buzzer went off while i was driving. It was very loud and annoying so when i got home i took out the fuse which made it stop, but when i pulled that fuse it made the overhead console stop working and the o/d light. The o/d still works just the light to indicate whether it's on or off doesn't turn on.
Anyways...I was wondering if anyone has had this problem? And what they did the fix it.
Old Aug 24, 2011 | 09:25 PM
Ham Bone's Avatar
Ham Bone
The remote key doesnt stop it?
Old Aug 24, 2011 | 09:42 PM
zje400ex's Avatar
zje400ex
No. The buzzer stays on when you turn the truck on. It's the buzzer for when you leave the lights on when you shut the truck off.
Old Aug 24, 2011 | 09:55 PM
Ham Bone's Avatar
Ham Bone
I'm no genius but obviously it thinks something is still on. Don't know how to fix sorry
Old Aug 25, 2011 | 06:36 AM
Novarider's Avatar
Novarider
Lactate the buzzer and remove it if you can't figure out what's making it happen.
Old Aug 25, 2011 | 07:22 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Check/replace the door jamb switches. Does the dome light work?
Old Aug 25, 2011 | 12:51 PM
TheycallmeLaramie's Avatar
TheycallmeLaramie
My door jam switch was stronger then the sheet metal on mine and had dented it in causing it to buzz when i drove on the freeway randomly. First i used adhesive foam tape, then after adding a couple layers i said screw it and used a sheet metal screw where the buzzer hits the door to beef it up and viola no problem.
Old Aug 25, 2011 | 04:09 PM
zje400ex's Avatar
zje400ex
Dome lights work. I'll have to mess with the door jam switch. Thanks for the advice.
Old Aug 25, 2011 | 04:33 PM
zman17's Avatar
zman17
Don't mess with them, replace them. They are cheap even if it's not the problem. At least they will be eliminated as the problem.
Old Aug 25, 2011 | 09:03 PM
zje400ex's Avatar
zje400ex
I've been super busy with work, but i checked it out real quick and the driver door has a small dent where the door jam switch is supposed to hit. So when the door is closed the buzzer must stay on. It should be a very easy fix. Thanks for the help guys
