Skid Plate
Old Aug 30, 2011 | 03:55 PM
zman17's Avatar
zman17
Retired Moderator - RIP
3:55's are "high" .Depending on the tire size you go to some day, you'll want 4:10's or 4:56's.
Old Aug 30, 2011 | 03:57 PM
stewie01's Avatar
stewie01
Ok. So higher the ratio the lower the gear?
Old Aug 30, 2011 | 04:01 PM
zman17's Avatar
zman17
yes, in simple terms. I know , seems backwards.
Old Aug 30, 2011 | 04:03 PM
stewie01's Avatar
stewie01
Unless I sell or change my mind on the 17" wheels I plan to run the stock size for that wheel.
Old Aug 30, 2011 | 04:04 PM
zman17's Avatar
zman17
In even simpler terms, most everyone that has a Ram 1500(non off road edition) has crappy gears.
Old Aug 30, 2011 | 04:08 PM
stewie01's Avatar
stewie01
Yeah my rear diff is probably needing some attention soon. The pumpkin shows signs internal leaking, got the "wet" spots but no leaking to the ground. I was even looking at locker's for it too.
Your right, time for a 4x4!
Old Aug 30, 2011 | 04:12 PM
zman17's Avatar
zman17
Only difference is a 2wd is cheaper to fix. They don't even get any surmountable amount of better MPG's.
Old Aug 30, 2011 | 04:15 PM
stewie01's Avatar
stewie01
Honestly I would expect a MPG decrease with a 4x4 truck. I looked at the sticker on the door of my truck (quad cab) and the rear end is a bit heavier then the front.
I know that would be different with all the extra stuff up front for the 4x4.
Old Aug 30, 2011 | 04:26 PM
zman17's Avatar
zman17
Not that much, is what I'm saying. And if you add in the oversize tire's, the difference isn't that great. 1 or 2 MPG at the most. You have to do what makes you happy , that is the bottom line. Have fun and do what you want to your truck. It's yours, and that's all matters.
Old Aug 30, 2011 | 04:31 PM
stewie01's Avatar
stewie01
Well this truck is bought and paid for, so either way whatever I decide to do, I don't have to worry about making a truck payment
Thanks for for help.
