Manifold backfire
Old Sep 8, 2011 | 12:06 PM
crazzywolfie's Avatar
crazzywolfie
^i agree
if the valve seals where bad you would know it when you fire it up first thing in the morning or after it has sat for a couple of hours. oil would have a chance to drip into the cylinder and would cause the truck to smoke way more than normal when you fire it up and eventually disappear.
Old Sep 8, 2011 | 12:07 PM
zman17's Avatar
zman17
Retired Moderator - RIP
"No I have not replaced the O2 or have I checked the cat" Why?
3gts in 6 miles? Rings and valve seals I'd say, or you forgot to use a gasket for the plenum.
And as Merc said, compression test.
