Brake Issues
Old Jul 21, 2005 | 01:40 PM
moparman95's Avatar
moparman95
Default Brake Issues
I was driving my truck to work yesterday and I went to stop and my pedal went to the floor. I pulled over and saw a nice big puddle of brake fluid on the ground. I had it towed back to my house so I could figure out which Line it was. I replaced the line from the front to the back and replaced the rear brakehose while I was at it. I bled the system and the brakes are now working better than normal but the abs light and the brake light are still on for some reason. When I unplugged the rear abs wire would that cause the light to stay on? Do I need to hook up an obd1 scan tool and clear the codes since its a 95? Any help would be appreciated.
thanks
-Dave
Old Jul 22, 2005 | 12:11 AM
The Burning Rom's Avatar
The Burning Rom
Default RE: Brake Issues
I'm not sure why lights would come on just because you had the abs wires unplugged....unless you had it running while you had them unplugged. Does the truck have 4 wheel ABS or just RWAL?
To clear the codes, you can just disconnect the battery for an hour...if you don't have access to a code clearing device.
