Need help deciding....
Old Sep 15, 2011 | 07:38 PM
drtbker13's Avatar
drtbker13
Default Need help deciding....
I have a 2001 dodge ram 1500 5.9l v8 I was wondering cause I don't have alot of money for what I should do first I was thinking a lift kit or a exaust but I can't decide
Old Sep 15, 2011 | 08:18 PM
wyomingdodge7's Avatar
wyomingdodge7
It all depends on what you're doing with your truck. You have to give us more that that^^ so we can help you.
Old Sep 15, 2011 | 08:22 PM
chadhager03's Avatar
chadhager03
IMO a lift kit is way more useful and aesthetically pleasing. Plus (I don't know this for a fact since I haven't done an exhaust yet) the power gains from exhaust midifications aren't that extreme until you start spending big bucks. But a quality lift will be big bucks too, do you want an off road truck or city driver?
Old Sep 15, 2011 | 08:49 PM
gdstock's Avatar
gdstock
If money was a deciding factor (and it usually is) I would start with some basics that will either enhance performance and/or operation such as plenum, checing for worn suspension and steering parts, plugs and wires. Then if all is good, look at lift, exhaust or other things. A good lift is not much value if plenum blows and pulgs cat.
+1 depending on what and how you use the truck.
Old Sep 15, 2011 | 08:52 PM
chadhager03
Ya I agree with the above statement, because that's how I'm doing it myself. Fix the annoying things first then dive into cool things like that lol
Old Sep 15, 2011 | 09:36 PM
drtbker13's Avatar
drtbker13
I was thinking city and an little offroad
Old Sep 15, 2011 | 09:51 PM
mj23polaris's Avatar
mj23polaris
fix things that are bad then upgrade, keep the truck drivable, dont guy lift it sky high then own my trans went out.... or i shredded a ring gear... now my truck is jus spent money on lifting i cant even drive.....
Old Sep 16, 2011 | 01:08 AM
drtbker13's Avatar
drtbker13
im thinking maybe a 3 inch lift kit i dont want to start getting into gear problems and all the other stuff. but i want the biggest tire that would look good without affecting everything else if you know what i mean
Old Sep 16, 2011 | 01:38 AM
JSTMoto's Avatar
JSTMoto
Originally Posted by gdstock
If money was a deciding factor (and it usually is) I would start with some basics that will either enhance performance and/or operation such as plenum, checing for worn suspension and steering parts, plugs and wires. Then if all is good, look at lift, exhaust or other things. A good lift is not much value if plenum blows and plugs cat.
This x 100.
Also,
Check your brake line next to the gas tank to see if it's rusty.
Read the sticky Plenum Thread. All Magnum engines are equipped with this particular flaw which can do a number to your cat, your cylinder heads, and your gas mileage.
Old Sep 16, 2011 | 01:42 AM
drtbker13's Avatar
drtbker13
i was not really worryed about money cause i figured i wanted nice and good reliable parts. thats why i was ether choosing lift or exhaust but im choosing lift but i want a good lift but not to high not to worry about the tran and what ever else could be affected.
