DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   2nd Gen Ram Tech (https://dodgeforum.com/forum/2nd-gen-ram-tech-64/)
-   -   Ram won't run... (https://dodgeforum.com/forum/2nd-gen-ram-tech/304088-ram-wont-run.html)
ljaeda Sep 17, 2011 09:55 AM
Ram won't run...
I have a 96 1500 4x4 318 Ram. Ive replaced crankshaft sensor, camshaft sensor, coil, throttle pos. sensor. it will not run, it is not showing any fault codes accept battery was disconnected. it was. it turns over fine, sometimes it will run rough for very short time but then it goes up about to 1500 rpm and dies
jasonw Sep 18, 2011 03:27 AM
Welcome to DF.
First, before anything else, please read this:
https://dodgeforum.com/forum/dodge-ra...s-section.html
I will move this to the 2nd Gen (1994-2001) Ram section for ya.
Novarider Sep 18, 2011 06:38 AM
Does it just crank and not start?
HeyYou Sep 18, 2011 08:22 AM
Check fuel pressure.
marks18 Sep 18, 2011 11:38 AM
Yeah have you done the basic air, fuel, spark check?
ttrash91 Sep 21, 2011 06:34 AM
wow you're in the same boat as me, i'm in pa also...about 30 min from hershey
i take it there is spark and fuel if it runs...but something is shutting it down
idle up doesn't make sense either....
key on engine off check fuel pressure at rail 45-50 psi
© 2026 MH Sub I, LLC dba Internet Brands
