question about tires..........
Okay i finally got my rear lift on, i have a 2.5" front coil spring spacer for the front and i just installed a 1.5" block in the rear. I am looking at tires. i would like to get some bf goodrich all terrains size 315/75/16. which convert to 34.6" tires so 35's, will my truck clear these? also if i install the bushwhacker fender flares will i loose clearance ? and one last thing, would you recommend just going with 33's?
thanks
thanks
