1995 lift&tire questions
Old Sep 25, 2011 | 01:04 AM
cutthroatxxx's Avatar
cutthroatxxx
Default 1995 lift&tire questions
Hello all I recently boughtt a 95 slt club cab ram &it seems to sit a wee bit higher than some Ive seen there is about a 3 inch block under the leaf springs.It looks stock.Im wondering 2 things.First what are the biggest tires I can fit on this thing?Next whats the cheapest &fastest way to lift this thing up another 3 or 4 inches?I wont be off roading in it btw.Work while Im @it I mine as well ask will 20in rims off a 3rd gen fit this thing?Thanks in advance!
Old Sep 25, 2011 | 01:49 AM
Wombat Ranger's Avatar
Wombat Ranger
half ton or 3/4 ton? I get questions all the time in my 95 2500 about the amount of lift on it, i laugh and tell them its stock. I have 33's on it with no rubbing at all. With 2" leveling spacers i will clear 35's, up to 37's if i want to lose some plastic. If its a 1500 32's maybe?? then with a leveling kit youll be sittin pretty on 33-34's, 35's with plastic trimming. If your planning on these tires i'd find wheels with more positive offset then stock 3rd gen wheels. Also expect slight to moderate rub at lock, more if you run them stockers. But yes, they will fit.
The only full "kit" I would consider is Superlift's 5" kit. cost around $1300 Nothing else using the stock geometry is thought out very well. From there up I wouldnt buy a kit i'd piece my own kit together, and make the long arm links and brackets myself, or buy DC's long arm box kit.
Old Sep 25, 2011 | 02:03 AM
cutthroatxxx
Yeah I should of mentioned its a 1500....the spacers sound like a good idea.Got a link?
Old Sep 25, 2011 | 02:10 AM
Wombat Ranger
hellbentsteel.com are the best out there, and $65 shipped
http://www.hellbentsteel.com/product...eling-kit.html
Old Sep 25, 2011 | 02:14 AM
merc225hp's Avatar
merc225hp
There are lot's of good entry level kits out there on the market, look around at diff web sites and get an idea what is in one kit and not the other, the more complete a kit the better.
Start looking here at this site.
http://www.topguncustomz.com/
This has been covered many times here try a search to get some ideas.
Also please take the time to fill out your signature so we can help you better.
Old Sep 25, 2011 | 02:23 AM
Wombat Ranger
When (if) I build a real suspension for mine i will be using TGC's 8" Pro-rate coils. They are Saweet!
