O/d off?
Old Sep 28, 2011 | 09:41 PM
CNCgolf's Avatar
CNCgolf
Default O/d off?
Every now and then my overdrive light comes on saying it is off. Any reason this could be?
Old Sep 28, 2011 | 10:30 PM
gdstock's Avatar
gdstock
I would start by checking trans level (in neutral - not park). Also, if it not pretty clear or smells slightly burnt, I would change fluid and filter.
Old Sep 28, 2011 | 10:36 PM
SilverSS's Avatar
SilverSS
Is od actually off or does the light just come on? When does it happen? Are you towing, after you've been driving a while, etc.
Old Sep 28, 2011 | 10:50 PM
TheycallmeLaramie's Avatar
TheycallmeLaramie
might be stupid but you may have OD on all the time, and your bulb just works randomly when the bumps hit the filament together. Just a thought.
Old Sep 28, 2011 | 11:40 PM
CPTAFW163's Avatar
CPTAFW163
Does the OD turn off and you have the red light in the shape of a transmission come on?
The truck going OUT of overdrive is usually a bad torque converter. The actual reason the OD turns off is because the tranny gets too hot. Basically you cooked your tranny and that is a defense mechanism. I had the same thing happen to my 1996. The torque converter and governor solenoid were replaced and it worked fine.
