Really weird stumbling problem
Old Oct 11, 2011 | 06:59 PM
  #41
aim4squirrels's Avatar
aim4squirrels
Have you used carb or brake cleaner to check for vacuum leaks? (that's sure what it acts like....) if you don't find anything obvious, try capping off the lines that run to the reservoir under the cowl, and the heater controls.
I haven't tried that yet as I'm scared to start a fire, especially since the engine seems to have to be good and hot for it to happen.
Old Oct 11, 2011 | 07:06 PM
  #42
drewactual's Avatar
drewactual
what do you think the chances are the the brake booster diaphragm isn't sealing? I'm about 'reached' out..
Old Oct 11, 2011 | 07:58 PM
  #43
Hahns5.2's Avatar
Hahns5.2
Is it possible it's having some sort of misfire first, then the misfire causes the vacuum loss and the vacuum loss has nothing to do with the cause of the misfire? IMO falling vacuum wouldn't make it stumble, it would act as if the throttle was opened and would accelerate, those AFRs aren't nearly rich enough to make a warm engine stumble IMO.
Old Oct 13, 2011 | 08:19 PM
  #44
aim4squirrels
A little update:
I removed all of the MSD ignition system components. Running the stock coil.
The stutter is not gone, but it is reduced. Something in the MSD box was amplifying the problem.
Old Oct 23, 2011 | 12:45 AM
  #45
jondakotaguy's Avatar
jondakotaguy
Never mind..
Old Oct 23, 2011 | 03:33 AM
  #46
aim4squirrels
Still fighting this one, as an update
Old Nov 7, 2011 | 08:07 PM
  #47
jondakotaguy
Keep us posted!
Old Dec 3, 2011 | 02:29 PM
  #48
jondakotaguy
HOws it going? Dont forget to update
Old Mar 26, 2012 | 03:22 PM
  #49
Wombat Ranger's Avatar
Wombat Ranger
Sooo.... Did you ever figure it out?
Old Mar 26, 2012 | 04:10 PM
  #50
drewactual's Avatar
drewactual
He did...
His second gen turned into a challenger srt8... That's one helluva mod, yo..
