tranny question
Old Oct 7, 2011 | 06:09 PM
sam_priem's Avatar
sam_priem
Default tranny question
whenever i put my truck into gear (especially reverse) it makes a loud hard knock. my guess is the U-joint but i could be wrong. i had the tranny rebuilt when it was still under warranty. Also my 4WD light is on (no its not in 4WD) anytime i take it out of 4wd the light stays on. not urgent just curious.
Old Oct 7, 2011 | 06:26 PM
zman17's Avatar
zman17
Retired Moderator - RIP
http://www.dodgeram.org/tech/repair/..._engagment.htm
Old Oct 7, 2011 | 11:53 PM
JSTMoto's Avatar
JSTMoto
If your u-joints check out okay, then its your rear-end. The crush sleeve preload gets out of whack, causing pinion bearing problems from being loose. IMO, its simply a poor design.
Its common in the 9.25s. Most people just deal with the noise.
Here's an example of what I'm talking about:
http://youtu.be/LEHn8-9exnA
