Knocking front axle, joint
Old Oct 10, 2011 | 07:06 PM
  #21
beeker's Avatar
beeker
I had a bad front diff axle oil seal after getting a u joint fixed. Often if you pull the axle to work on the u joint it can damage the diff seal. To fix it the mechanic rigged up a piece of allthread with a grommet on the end to hold the new seal, got it done without opening the diff. Hope you can be so lucky too.
Old Oct 11, 2011 | 10:05 AM
  #22
calumetbud's Avatar
calumetbud
Just double checked the Ujoint, its in badd shape...So now I need to find the DIY and get r done
