MORE 46RE shifting issues
Old Oct 10, 2011 | 05:36 PM
gdstock's Avatar
gdstock
gdstock has a thread, as does rcky_mtn_ram. There is also a thread in the DIY section by J415, that has links to some VERY good resources.
If yougo to the DIY section of this forum, you can download the factory service manual, go to 46RE trans section. I printed this section and put it in plastic sheet covers and had it on the bench as I was working on it.
Governor solenoid, pressure sensor, and OD and TC solenoids are all accessible with pan removed. Theya re on the bottom of valve body.
