I got some weird advice about my transmission
Depends on where slipping occurs, the front band may take care of it. The band on the direct drum seems to need adjusting more often than rear - and it is located on the outside. I usually try to do what is accessible first - but if that does not correct it, then you are correct - drain and pull pan and adjust rear band.
Josh, go to the faq/diy section and download the manual. It ahs good troubleshooting in the trans section. It can lead you to which band may need adjusting and how to do it.
Thanks again, guys. I appreciate all the good advice.
