1999 2500 Diesel - your experience and expertise wanted...
Old Oct 16, 2011 | 01:46 PM
AHammerAndDuctTape's Avatar
AHammerAndDuctTape
Default 1999 2500 Diesel - your experience and expertise wanted...
1999 2500 2wd 5.9l 24v, 410 rear end, 47re, Banks 4" exhaust. Took my first decent road trip since purchasing a couple months ago. 300+ miles each way towing 3500lb travel trailer, traveled from 1500 ft above sea level to over 7,000 with 6+% grades some several miles long. Averaged about 65 MPH entire trip, even up grades. Would love to hear your thoughts on these stats. MPG going up - just under 13; MPG unloaded- about 20.5, MPG coming back - about 14 (all hand calcs, not lie-o-meter). EGT averaged 800 - 1,000 (occasionally close to 1100 on steep grades - 500 - 600 on down grades). Now for the $64,000 question - since this seems to be a common point of discussion: Would you have made this trip with O/D on or off? Thanks for your insights.
Last edited by AHammerAndDuctTape; Oct 16, 2011 at 01:56 PM. Reason: Added rear end gear ratio
Old Oct 16, 2011 | 02:33 PM
John D in CT's Avatar
John D in CT
Don't know much about your engine, but 20.5 mpg sounds pretty damn good to me; same with the loaded mpg.
From the sound of your route, I don't think I would have been in O/D for much of it. Zero % of the time when trailering (especially up- or downhill), and as "needed" when unloaded and on the flat.
Sounds like your rig is running very nicely.
Old Oct 16, 2011 | 03:02 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You should post in the oil burner section. You'll get more feed back from those guys.
Old Oct 16, 2011 | 06:46 PM
EndIsNear's Avatar
EndIsNear
I wouldn't have used overdrive when towing especially over the grades but when empty I would've left OD on. Your pickup would have enough power especially with 4.10s to pull itself over most grades without downshifting.
