headlight
Old Jul 26, 2005 | 12:59 AM
havok's Avatar
havok
Default headlight
Does anybody make aftermarket headlights?
1997 5.2L ram 2x4
JBA HEADERS STRAIGHT THROUGH EXHAUST
K&N AIR INTAKE
Old Jul 26, 2005 | 11:04 AM
4DrMopar's Avatar
4DrMopar
Default RE: headlight
unfortunatly, still no, clest you will find is 99-01 Sport headlights, dual bulb BIG improvement over stock, my next mod most likly...
Old Jul 27, 2005 | 03:18 AM
livinginh's Avatar
livinginh
are the 99-01 sports a direct bolt in for the 94 to 98? What would have to be done to install them?
Old Jul 27, 2005 | 04:52 PM
The Burning Rom's Avatar
The Burning Rom
Info:
http://www.turbodieselregister.com/f...s&pagenumber=1
http://www.dieseltruckresource.com/d...ort+headlights
http://www.dieseltruckresource.com/d...threadid=70533
You may have to register to view the threads. They're the only info I have on the swap. And there has to be some modification done to 98 and older trucks in order for them to fit. Some sheetmetal needs to be cut out behind the headlight. There's quite a bit of wiring that needs to be done however, and I recommend following the instructions that use relays. That way you won't risk melting anything.
