Old Aug 7, 2015, 02:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exhaust and Intake System
Print Wikipost
14x3 Air Filter Question....
Old Oct 16, 2011 | 11:58 PM
DogeRamGuy1993's Avatar
DogeRamGuy1993
Default 14x3 Air Filter Question....
Okay so i want to do it for sure. I checked out the DIY thread about it but i am unsure on a couple things.
1st- What size bolt will i need?
2nd- is their a certain size breather or what is it called if i were to look it up on advance auto?
3rd- will this set any codes off?
4th- is this exactly like a cold air intake?
Just some questions a newbie like me is unsure about. thanks everyone
Old Oct 17, 2011 | 12:14 AM
merc225hp's Avatar
merc225hp
Here's a diy link to help you out.
1: 1/4 threaded rod or ready rod
3: it should not set a cel
4: no it's nothing like a cai
https://dodgeforum.com/forum/2nd-gen...-assembly.html
Old Oct 17, 2011 | 12:19 AM
DogeRamGuy1993
What is the correct term for the 1/2 spacer i need, i cant find one on advance auto parts. And why do i need to bend the rod? lastly will this do anything performance wise then if its not like a CAI?
thanks
Old Oct 17, 2011 | 12:32 AM
merc225hp's Avatar
merc225hp
thanks
I am "not" using this setup so my answers are limited
Spacer not to sure, the bent rod or s rod is needed because the hole for the bolt is not centered to the TB. As for performance gain I am not to sure, some will say yes some no, I do know it will be loud, not exhaust loud but sucking air loud.
Edit: found this about the spacer https://dodgeforum.com/forum/2nd-gen...14x3-help.html
