Tps?
Old Oct 28, 2011 | 04:36 PM
99SLTdriver's Avatar
99SLTdriver
Default Tps?
I had the day off so i decided to look over some things on my truck. I checked the TPS and I get a reading of .001 at idle and .162 at wot.Is my TPS bad?
Old Oct 28, 2011 | 04:50 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Do you have a problem, that made you check it? You didn't test it while the truck was running did you? Get a Haynes manual if you don't have one and download the free FSM from the FAQ/DIY section. Both will have all the info and values on testing all the sensors.
Old Oct 28, 2011 | 04:54 PM
99SLTdriver
No problem,just bored and wanted to learn something.I tested it with the key on but not running.
Old Oct 28, 2011 | 05:01 PM
zman17's Avatar
zman17
Like I said, get the Haynes or do the free download. But, 0.5 to 1.5 with throttle fully closed is normal. And anywhere from 3.5 to 4.5 at WOT is normal. All I can say, is , if it ain't broke don't fix it.
