Wheel cylinder replaced abs light on
Old Oct 28, 2011 | 05:00 PM
Joey Buentello's Avatar
Joey Buentello
Default Wheel cylinder replaced abs light on
My buddy replaced/ rebuilt my driver rear wheel cyinder. Works fine but now my abs light is on and my brake light they both turn off when i hit my brakes though. My abs has not worked since i bought the truck in 05. Thanks for the help.
Old Oct 28, 2011 | 09:45 PM
dsertdog56's Avatar
dsertdog56
Theres a process to rebleed the system which may help. I believe the manual download has it or you can look it up.
You may have to let it gravity bleed (and keep the resevior full) to refill the pump and get any trapped air out.
Old Oct 29, 2011 | 04:13 AM
Joey Buentello
Thank you
Old Oct 29, 2011 | 08:15 PM
Joey Buentello
Rebled the brakes all is well.
Old Oct 30, 2011 | 06:05 PM
Joey Buentello
nevermind my ABS and brake lights are still on
Old Oct 30, 2011 | 06:29 PM
ToastKing30's Avatar
ToastKing30
Had the same problem when I replaced the brake line along the frame after I bled them the light came back, I ended up cracking all the bleeders to let it gravity bleed on thier own and the light went away. Just make sure you dont let it run out of fluid. check on it every few minutes.
Old Nov 1, 2011 | 12:45 AM
Joey Buentello
cool beans
