Searched multi threads to no avail so I need you guys.
I have a 94 Dodge Ram 1500. Blinkers and radio stopped working. At first it was intermittent but its now apparantly permanent. Through searching I figured it to be a bad ignition switch, so I replaced it after checking all fuses of coarse and that didn't fix it. I looked for loose wires and nothing. Any ideas what the heck I should check?replace now? Thanks.
If you have a tilt wheel, remove the column covers and inspect the wires running down it, and check the plug on the back of the multi function switch while your in there.
