oil pressure acting funny
Old Nov 4, 2011 | 01:26 PM
scrappy2686's Avatar
scrappy2686
Default oil pressure acting funny
ok 96 dodge ram 5.2, put a brand new oil pump in about a month ago and oil pressure was fine, then i had my oil leak. well my oil leak has finally subsided from the oil pan and now coming from the valve covers which im not worried about. this morning i went to start her up and the oil pressure jumped up to 40 then dropped to 0 immediately afterwards.oil sending switch maybe or just the strain getting clogged maybe? anyone have any suggestions. my oil level is just right so im a little dumbfounded right now.
Old Nov 4, 2011 | 01:42 PM
charlie1935's Avatar
charlie1935
If you don't hear any lifter noise it may well be the sending unit. I have had them leak and oil run down the back passenger side of the motor and thought it was a valve cover also.
Old Nov 4, 2011 | 01:45 PM
scrappy2686
did it also make you think it was the oil pan leaking as well . so back passenger side of the motor is where im looking right. gimme 2 minutes and i will be back and let ya know
Old Nov 4, 2011 | 01:52 PM
scrappy2686
yep it is covered in oil so that will be replaced today. i had a feeling it was it but thanks for the input and clarification i knew i joined this forum for a reason lol
