Another coil spacer question
Old Nov 8, 2011 | 08:00 PM
tssiTanker's Avatar
tssiTanker
Default Another coil spacer question
98 2WD 5.2 Ram 1500
I was reading on here to measure the difference between the height on the edge of the front and rear wheel well. I measured it and the difference is basically 5in.
My question is will a 2.5 coil spacer make it look like it is even with the rear?
I was also reading about rear lift blocks, and someone had said don't use them if you intend to off road.
Why is this? Or is that wrong? because I really haven't found anywhere else on here that says this.
