Air Intake Gasket?
Old Nov 15, 2011 | 11:34 PM
badrhino's Avatar
badrhino
Default Air Intake Gasket?
I have a 1995 Dodge Ram 1500 pick-up with the 318 auto.
I noticed when I had the air cleaner system off that when I put the piece back on the throttle body,it sat on there kinda loose and did not quite fit tight enough and would surely be letting in unfiltered air. I don't believe there was a gasket in the air cleaner assembly that fits between it and the throttle body. Is there supposed to be a gasket? If so where can I get one cheap?
Thanks!
Old Nov 16, 2011 | 12:01 AM
bekins01ram's Avatar
bekins01ram
there is a gasket, and it can be found at any of your local parts stores for under 5$.
Old Nov 16, 2011 | 12:14 AM
bwdakrt's Avatar
bwdakrt
Felpro part # 60038 $1.69 at O'reilly's.
http://www.oreillyauto.com/site/c/de...2542&ppt=C0026
Old Nov 16, 2011 | 08:45 PM
badrhino's Avatar
badrhino
Thanks Guys!
I thought there should be one on there. I'm wondering if that is why it runs a little funny sometimes. Would that have any effect if it was getting air from around the throttle body / air cleaner connection....I don't think these have a MAF sensor do they?
Old Nov 16, 2011 | 09:09 PM
gdstock's Avatar
gdstock
No MAF. If it runs funny at idle, check IAC as well. And check plenum as well. That could do it.
