HELP!!! Loud rattle on hard acceleration.
Old Nov 17, 2011 | 11:26 PM
rumble_truck's Avatar
rumble_truck
Coolant loss could be the bypass hose in the intake, I blew that one out and it took me forever to fix.
As for rattling.. Haven't got a clue...
Old Nov 18, 2011 | 05:52 AM
ndalip416's Avatar
ndalip416
Thanks for the info guys. I gotta funny feeling it's the plenum. I watched a YouTube bid on replacing the plenum. When he took the intake off there was coolant sitting in slots next to the gaskets. The only doubts I have is when I checked in the throttle body there was very little oil. And my truck doesnt burn oil at all. I've read if you have a bad plenum it eats oil up. As for coolant disappearing, I checked at thermostat, timing cover, overflow is not cracked. No coolant on pass floor. And it doesn't smoke. I'm gonna change the plugs wires cap and rotor. See if I get any power outta this dog and if pinging stops. I appreciate everything guys. Thanks for all the replies it's been helpful.
Old Nov 18, 2011 | 08:44 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Originally Posted by jswain
For the rattle on heavy acceleration, I would check or go ahead and replace the plugs, plug wires, and distributor cap before I did the plenum.
All you're advocating is replacing a bunch of parts rather than properly diagnosing the problem
I like to try the cheap and easy first. Kinda like you do with the ladies before you get married, ya know?
How is needlessly spending money "cheap and easy"?
Old Nov 19, 2011 | 11:55 AM
jswain's Avatar
jswain
Nope, VW, have to disagree. He just bought the truck with 130 k miles. Probably has no idea when plugs, wires, etc, were replaced. I'm advocating taking care of routine maintenance issues before tearing into the plenum.
Old Nov 19, 2011 | 12:02 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The OP needs remove the TB and look around with a light and a small mirror. Looking down the plates is worthless. And since he'll have the air cleaner housing off to do the cap and rotor, only a few more steps and he can check the plenum for real.
