Gear oil advice
Old Nov 18, 2011 | 02:22 PM
Racer26's Avatar
Racer26
Default Gear oil advice
I have a 2001 1500 V6 5-Speed (2wd, 9.25 rear end) that I am going to be doing a gear swap with from 3.55s to 4.88s as I'm doing a lift with 35" tires. I use this truck for towing as well. I will also be running a Lockright locker.
Would 85W/140 synthetic gear oil be too thick? Would 75W/140 be better?
This truck stays mostly in Arizona, or at least the west, so during the summer, it sees temps over 100 on a constant basis, and during the winter, nothing colder than about 30 overnight, but regularly in the 70s.
Thanks!
Old Nov 21, 2011 | 02:47 PM
Aubrey's Avatar
Aubrey
Run the heavier and if you can, get one of the covers that holds more fluid.
