Old Aug 7, 2015, 05:21 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension
Print Wikipost
Power Steering Pump Removal Question
Old Nov 24, 2011 | 02:40 AM
jdh0921's Avatar
jdh0921
Default Power Steering Pump Removal Question
I'm being a good boy and following the manual (part of the problem with this question is the time, 1:30 AM here). I've removed the serpentine belt, and getting ready to remove the hoses from the pump, and had this question. On this step :
Remove the hoses from the power steering
pump and cap the fittings.
What fittings am I capping exactly? Am I capping the hoses or am I capping something at the pump, so when I spin it around it doesn't puke massively. If so, what should I use to plug it, I imagine a paper towel won't suffice..
Its probably a newbie question but it is late so I'm not thinking clearing (also no rush).
Thanks!
Old Nov 24, 2011 | 03:13 AM
J415's Avatar
J415
Don't know, but maybe this will help:
https://dodgeforum.com/forum/2nd-gen...p-rebuild.html
http://www.corvette-restoration.com/...mp_rebuild.htm
Old Nov 24, 2011 | 07:01 AM
zman17's Avatar
zman17
Retired Moderator - RIP
You use some rubber vacuum plugs or plastic caps of the appropriate sizes. And yes, it's just so the fluid doesn't pour out of the pump and hoses. If you have the new pump, it should have a couple on it for the pump anyway.
