Burnout Question.
Old Nov 26, 2011 | 02:05 AM
godzilla8.0's Avatar
godzilla8.0
Cool Burnout Question.
hi, i just added myself to this site in hopes that people could answer my questions, so heres my first one.
i have a 1998 dodge ram 2500 v10, ilke to do burnouts with it but only the rear right side tire will spin. i asked my friend and he said that it could be that my left rear brake works better than my right rear brake causing only the right rear tire to spin. what do you think the reason for this is?
Old Nov 26, 2011 | 03:33 AM
Lonewolfwd's Avatar
Lonewolfwd
Well with my experience on burnouts from when I was racing it would be a limited slip differential that you have and not a posi trac. If that's the case then you can either replace it with a posi or in my case I had always either used a Detroit locker or I would bolt the differential together with grade 8 bolts if possible.
Old Nov 30, 2011 | 11:14 PM
socket462's Avatar
socket462
I can help you!!
Go Here!!
http://lmgtfy.com/?q=open+differential
