another 2wd lift thread
Old Dec 7, 2011 | 04:59 PM
97_ram1500's Avatar
97_ram1500
Default another 2wd lift thread
do the lift spindles put the front track width out any wider than stock? and would 33s fit with lift spindles, 2' lift coils, and 3" lift blocks and still be a level stance? my front is about 1.75 lower than the rear and i know the coils will settle a little after a while.
Old Dec 7, 2011 | 06:53 PM
(texas-ram)325HP's Avatar
(texas-ram)325HP
Spindles will make the front tires stick out more make it look like a baja style when looking straight at the truck. 33s will fit with a 3inch spindle lift alone my girlfriends brother had it done to his first truck before he got a hemi
Old Dec 7, 2011 | 07:23 PM
Trent479's Avatar
Trent479
Spindles do push out the wheels! Yes the 33's should fit just right!
Old Dec 7, 2011 | 09:52 PM
EndIsNear's Avatar
EndIsNear
My 33's fit with a 1.5" spacer alone.
Old Dec 7, 2011 | 10:37 PM
97_ram1500's Avatar
97_ram1500
how much thought? i know they push them out but how much cause i need to find rear spacers to make it look the same.
Old Dec 7, 2011 | 11:03 PM
EndIsNear's Avatar
EndIsNear
Hold on ill post some pics of a 6" lift front and rear difference. Should give you a good idea. Its not much.
Old Dec 7, 2011 | 11:11 PM
EndIsNear's Avatar
EndIsNear
Nevermind. They aren't on my phone. I guess I deleted them a while back. The difference shouldn't be more than 2" wider I THINK. As they sit in stock form, the front is actually narrower than the rear. 4X4s front end is wider than a 2WDs. So you might match, if not, be slightly wider, than a typical 4X4.
Old Dec 8, 2011 | 02:32 AM
dodgeram07's Avatar
dodgeram07
and also you may need to buy new rims to clear the spindles!!!
Old Dec 8, 2011 | 08:10 AM
(texas-ram)325HP
You will need new rims and the spindles do not stick out that much really cant tell to me
Old Dec 8, 2011 | 11:23 AM
97_ram1500's Avatar
97_ram1500
i getting new rims for sure, im actually kinda liking the black and chrome incubus rims, the ones that look similar to street locks. and going to go with bfg m/t's for tires. but just cant decide which lift i want to go with honestly.
