'99 Ram 1500 Brake Upgrade
Old Apr 14, 2016 | 12:42 PM
  #51
dbbd1's Avatar
dbbd1
My rears (1500) do not have the slot. It is " kind of" there but not really a knockout.
Of course, it is still a good idea of where to locate the adjuster.
Old Apr 15, 2016 | 11:23 PM
  #52
adukart's Avatar
adukart
Just to add some info on the upgrade part, I just put 1998 8800 gvw 2500 calipers in my 98 1500 4x4 and they work great.
Old Jul 10, 2016 | 05:29 AM
  #53
Jonfarmer's Avatar
Jonfarmer
Default Sorry to reactivate thread
Originally Posted by slowtruck99
I still haven't done my brakes yet... I'm putting it off til the end of the month, they need a little more love than just calipers & pads. Lol!
I believe u can install 2500LD calipers on your 99. I don't think they made a 7500LD in 99. The pad are supposed to be the same as 1500 pads. I would make sure they fit before u leave the store though.
I'm thinking about doing the 2500LD on my 99 1500. Can you give any advice on your upgrade? Did you have any issues arise? Do the 1500 pads and rotors fit on the 99 1500?
Old Jul 10, 2016 | 09:33 AM
  #54
Spillage's Avatar
Spillage
These are the parts I used on my '98 1500 brake upgrade.
Front Cyl 80mmØ from 2500LD (stock 1500 are 75mmØ) - AC Delco 18FR741 & 18FR742
Rear Cyl 28mmØ from 2500/3500HD (stock 1500 are 24mmØ) - AC Delco 18E112
Discs/Pads & Drums/Shoes are stock 1500.
If you want more braking in the rear, use the GM3500 cyl 30mmØ - NAPA #37337
All these parts are direct bolt up, no mods needed.
Old Jul 10, 2016 | 10:12 AM
  #55
dbbd1's Avatar
dbbd1
Yup, I used the stock 2500 calipers with 1500 pads in front, 1500 pads with 2500 cylinders in rear. No mods needed. With no load in the truck, the rear seems to lock up easier (duh, of course) even before the rear abs kicks in.
Old Jul 10, 2016 | 03:30 PM
  #56
Spillage's Avatar
Spillage
Originally Posted by dbbd1
...With no load in the truck, the rear seems to lock up easier (duh, of course) even before the rear abs kicks in.
That's why I stopped with the RAM2500/3500 cyl... I don't often carry a lot of weight.
If I had a LB and carried heavier loads regularly, I might have been tempted to use the GM3500 cyl.
Old Jul 11, 2016 | 09:49 AM
  #57
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
I did the same upgrade as Adukart, works great! Only difference is I went with 2500 pads in the front.
Old Jul 12, 2016 | 05:29 AM
  #58
Jonfarmer's Avatar
Jonfarmer
Do you use the same 1500 rotors as well? How long was the job to switch them over? Is autozones product a decent product?
Old Jul 12, 2016 | 07:11 AM
  #59
Spillage's Avatar
Spillage
You have to use the 1500 rotors (5 stud).
Old Jul 12, 2016 | 08:39 PM
  #60
dbbd1's Avatar
dbbd1
^X2. Yes.
