p0455
Old Dec 15, 2011 | 12:57 AM
biggreen2500's Avatar
biggreen2500
Default p0455
so my CEL came on tonight... with the code P0455 anyone know what that is
Old Dec 15, 2011 | 02:17 AM
UnregisteredUser's Avatar
UnregisteredUser
That's a purge system problem, most often just a broken vacuum line or a failed gas cap.
Old Dec 15, 2011 | 03:16 AM
biggreen2500
i did get gas today... i double checked gas cap seems tight but i know the seals do wear out... as far as it having a CEL it won't make it run bad or anything will it ?
Old Dec 15, 2011 | 06:13 AM
LoneWolfArcher's Avatar
LoneWolfArcher
No., some claim it will affect mpg, but many have driven with codes for that fire a long time.
The worst part about it that I can see is that if your get another more pressing cel your might not notice it cause you'll assume that it is the same evap code.
Old Dec 15, 2011 | 04:46 PM
biggreen2500
well each time my CEL comes on i check it. i pull over and do the key trick... i've had it come on before i does it like once every 3 months i get the P0455 so i figured i'd ask about it since it keeps happening.
well i'm just not gonna worry about it then.. thanks for the advice
