Fuel System Pressure Release procedure
Old Dec 18, 2011 | 11:35 AM
byronpen's Avatar
byronpen
Default Fuel System Pressure Release procedure
How do you do this safely
Old Dec 18, 2011 | 11:46 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Disconnect negative battery cable first. Get a rag and hold it over the valve on the fuel rail and press the valve. For a more detailed description, get a Haynes and download one of the service manuals from the FAQ/DIY section.
Old Dec 18, 2011 | 11:48 AM
byronpen's Avatar
byronpen
ok then i was reading it right
Old Dec 18, 2011 | 11:50 AM
zman17's Avatar
zman17
I guess so.
Old Dec 18, 2011 | 04:51 PM
97ramrod1500's Avatar
97ramrod1500
you can also pull the fuel pump relay and start the truck. It will run for 3 seconds and die. this will take all the pressure off the fuel rails. much safer than pulling the fuel line.
