Clear understanding of overdrive?
Old Dec 18, 2011 | 09:29 PM
SweetTooth's Avatar
SweetTooth
Originally Posted by gdstock
You may also want to check the adjustment on the TV cable. If it is not adjusted correctly, the transmission will not kick down like you need when passing.
I actually just watched a video explaining it.
I'm scared to adjust it hah, I'd hate to burn up a trans.
Old Dec 18, 2011 | 10:07 PM
gdstock's Avatar
gdstock
TV cable is on pass side of TB. Disconnect from TB and see if it is aligned with the TB connector while TB is closed.
In the FAQ/DIY section there is a service manual you can download. The TV cable adjustment procedure is section 21, page 597.
Old Dec 18, 2011 | 10:19 PM
UnregisteredUser's Avatar
UnregisteredUser
It's not adjusting the thing that stresses the transmission. The cable stretches, and stretch reduces line pressure in the transmission.
Old Dec 19, 2011 | 02:52 AM
chadhager03's Avatar
chadhager03
Does od off turn off
Old Dec 19, 2011 | 02:54 AM
chadhager03
Does "od off" turn off torque management? It seems like my truck has a lot more power from stopped. I can even spin my tires a little whereas od on I couldnt. But it could have just been a coincidence
Old Dec 19, 2011 | 04:06 AM
working4ev's Avatar
working4ev
Would you have the link to the video??
